I agree with you 100%. If the block was properly boiled out upon rebuilding, neither product will offer any 'help'. I have rebuilt numerous flatheads and have used both products on occasion only to find no difference in temp readings.if you havent bored an excessive amount, .125 or more, your block and heads arent cracked, engine in good shape, a good radiator and good water pumps, i see your running skips, you dont that stuff, if you do you have a serious emgine problem, find out what it is and fix it
Either.Can you use PI or WW with anti freeze or just water ?![]()
marty howsthe car coming on trev
Actually, Four thing's. Those three and Skip's pumpsI used it when i put in Skips rebuilt pumps. It's in his coolant recomendation. It might have helped a bit but it was not a major contributor for cooling. It definately can't hurt to use the stuff. Three things are needed for decent cooling. Water flow, Air flow and correct timing.
I like the watter wetter.
Won't have the 39 ready, but able to help if anyone breaks down39portlander, Yup, the Skips pumps take care of #1. Are you going to join in on the "Downeast Barner Bash"?
Is there someone out there that would know if there is a difference between waterwetter & purple ice other than the price ? Any info would be appreciated as I just put Skip's pumps on my 34. Thank you.
Gary.
