Rollingmenace
Long first post my 51 is finally here and my first order of buisness is the fuel system... the fuel in the tank is really old.. lines are suspect want to test sender ect ect..
Asteticly id like to keep the look under the hood vintage with the modern hot rod goodies..
Im basically going to pull and clean tank, test sender and replace everything carb, lines, filter, pump and sender if needed
im planning on rewiring entire car with a 12 v conversion but ill leave that for another time...
i had a few questions and would like some opinions
#1 as far as the stock fuel pump on the car the eventual plan will be an electric pump but untill the wiring deal i want to run my stock mechanical once switched over to electric would you guys recomend just ditching the stock unit or will it be better to run it in conjuction im trying to avoid any heat transfer and vapor lock issues
#2 if i remove the stock pump is there a blockoff kit that can work for it... ive seen ones up to 1950 but really nothing for the 51 (are they the same)
#3 will removing pump have any affects on how the engine runs..(i recall something being said about the mechanical load the pump has on the engine)
#4 lines im planning on aluminum. gone right and rubber to isolate. any thoughts?? i believe they have been replaced at one time im thinking there copper in there now
#5 electric pump im planning on just a universal pump im thinking on frame rail as close to tank as i can .. my brother seems to think it needs to be closer to the carb.. what are your thoughts
#6 filter and regulator. as far as regulator should it be closest as possible to electric pump or is under the hood fine.. and my filter im looking at either a canister style or a billet style both with changable elements..do you think regulator with filter mounted on firewall possibly with a little fuel pressure guage would look ok
Thats enough for now any opinions or advice would be appreciated
