edhd58
Is it possible to have spark when starter motor cranking an engine but it not be enough spark to start the motor?
This damn 226 G has quit again.
I have pulled the head to make sure the cam and crank are in time, they are.
I have fuel to the carb so that the accelerator pump will squirt fuel, and I have had the carb back apart to try to be certain all the passages are open. Everywhere I've squirted cleaner it has shot out another hole somewhere else on the carb. The tops of the piston are getting black like its not burning all the fuel (too rich or not enuf spark?)
The float level has been raised and lowered, its a little lower than I think it needs to be right now but the accelerator pump still squirts.
I have a new set of points installed and set at 0.016, but I dont have a new condenser and no parts house has one that fits this or the H 226. I'm going to get a condenser for something and try that.
I was just wondering if you can have spark but not enough spark to start.
I havent changed coils, Its a 12v coil in a case that looks original. I'm hoping to not have to change that, but it is what it is when it comes down to it.
