You fixed it Mike! I put the fuse in and the draw was still there. Turned the key off and got under the car. There's a small steel hanger on the frame with two wires from the governor and another wire bundled together in it to keep them out of harm's way. I pulled the harness out, peeled it back and separated the wires a little and Presto, the ammeter draw was not there with ignition on. I crossed my fingers, got in the car and took off on about my 14th test drive. Everything works, goes in to OD above 28 when I let up,, comes out at 21, kicks down as it should and lever can be pulled out at rest. I'm a happy camper. Thanks to all the guys who chipped in with advice and suggestions.
