1931 flamingo
ReRead the above and ck the axle keys. Yes, the drums have to be removed.
Paul in CT
Paul in CT
Is it possible the ujoint is not engaged, or barely so?
Those keys look fairly normal, but the radial grooves indicate past problems. On a new axle that area is smooth to mate with the hub.
When the axle nuts are torqued properly, the hubs ARE hard to get off because the hub is driven due to friction on the taper NOT the key. Using a KR Wilson puller is the best way to accomplish that removal task.
When you remove the rear end, make sure the U joint is not broken. If I understand everything you have described something must be amiss with the driveshaft itself. IF that was a 32 rear end with the pinion held on with a nut and key, I would suspect that. I see from your picture though that it is a 6 spline pinion and driveline.
Let us know what you find! Good luck, I hope it is something simple.
