Is it okay to shift the Mitchell O.D. while moving?
1 low
2 low
2 high
3 low
3 high
Works best IMO.
Yup, especially in hilly country. Things can be busy in there during the high 2nd-low 3rd change. That said, I try to keep my changes in the OD to a minimum. The synchro is weak (always has been).
I recently was on a hill where I needed high 1st. The motor in my car is pretty peppy so it was no wonder a few of the others didn't get up there.
Just curious, what do you mean by "the synchro is weak". Just so I can understand.
I can't remember anyone mentioning any issues with a Mitchell. Has there been any failures?
No failures as such but both the transmission and the O/D are crunchy when I change. They started off OK but didn't last well.
BTW, I've been driving manual transmissions all my life.
It sounds like your clutch may not be completely disengaging?
I have over 16K miles on my Mitchell Transmission and O.D. and they both still shift quietly. I also do a lot of mountain driving and use the O.D. as a gear splitter. Second w/O.D. is a very useful gear.
My experience.
Chris W.
Thanks Synchro. Mine has been a bit "crunchy" since new and I just thought that is the way they were. I have only driven one other Mitchell equipped Model A and it was the same. I have learned to not try to "slow shift" a Mitchell like you would a stock transmission and it shifts better. I also have found that if I "blip" the throttle on downshift, it shifts better.
I see others have the same issue further in this thread.
I guess I did not realize that the Mitchell OD was not built to "last a lifetime". I had heard the syncro-trans units don't last forever.
Louie Glen,
Everyone here is assuming that you know to put the clutch in while shifting the Mitchell overdrive.
I am one of the 5% of Mitchell owners that has a cable control. I Have a second Mitchell on order and am definitely going with the cable. Second high to third low is a breeze, just drop it into neutral, push in the shifter mounted cable, and continue into third. One smooth motion. Far better than twin sticks. Down shifting is just as nice. The top gear is nice, but the split shift is awesome.
Yup, wished mine was. Would be more like a 2-spd truck axle.
The two sticks just aren’t positioned for ease of shifting.
Do they have a conversion kit ?
