Jack Shaft
Quick shift the mitchell,shift it as fast as you can.to me,the mitchell stick is too short.
The cable kit comes with everything you will need to change over
Thanks. Will give them a call.
Can you post a pic of the shifter mount in yours ?
The shift knob is mounted on the gear stick and is pulled straight up for O/D, down for O/D off. Throw is about 2"
Not sure how to put the cable in a "neutral" position, just in is for OD and out is for stock gearing ?
Ya, buts that’s a pretty crude pic. Would like to see how it fits in the vehicle and how much cable throw is needed before ordering.
I bit the bullet a few days ago and ordered my Mitchel O.D. Steve and Cyndi were super helpful. They are still 12 weeks out on orders but I know it will be worth the wait to cruise a little smoother and quieter in the Town Sedan. Bob
The Mitchell overdrive housing for a Victoria is 4.5 inches further forward on the drive train to help clear the dropped floor pan. It should also have the top rear corner machined off at an angle. Gluing a strip of quarter inch thick rubber onto the machined area will cushion it if it bottoms out. Replacing the 8-leaf spring with a 10-leaf spring also provides a little more clearance.
The floor pan is not that hard to remove from the car. You can take it to a sheet metal shop and have the front section cut away and boxed if you carry a lot of weight in the back.
Tom Endy
Not doubting you, but I would have thought it be the opposite since you push the shift lever forward for O/D thus it pushes the O/D shift rod in. Down on the cable would push, not pull? Or does it work on a bell crank type setup. Inquiring minds.![]()
The O/D unit needs to be a few inches further back for a Tourer. They hit the curtain tray under the floor.
The cable is quite long and does a loop behind the O/D and connects from the back via a bracket mounted on the unit to holes that are already in it. You may have seen the tapped holes and wondered why they were there.
