whirnot
Everything you need for a cable control is included. As far as length, you just tell them you are mounting to the shifter and it is the correct length with the brackets. The height on the shifter is adjustable by moving the brackets up or down. It can be configured so that cable out is high, or low, and vice versa. I will see if I can get a photo.
