No pics from me as mine is Aluminum. Its also 6.7 o 1 14mm plugs
hardtimes,
I would definitely, and I'm sure others, like to see some good clear pics of your Simmons Super Power Head!![]()
Bob-A![]()
More on Simmons
click> Model A Simmons Super Power Head on Ford Garage
Most used ones I have had or seen had at least one crack in the square combustion corner above the piston on at least one cylinder.
Also the spark plug placement is different than stock, not working well with original distributor bodies.
I was asked by someone about having an iron Thomas head made from my new tooling.
never seen an iron Thomas-but here is an iron Lions Head
01492-3
LION SPEED HEAD III cast iron 6:5 4 PLUG 14MM 14MM PLUG THREAD
Cast iron, fully machined, 14mm plug threads. Plugs on the driver side at 45 degree angle. Fins help with cooling. Use the stock Model A water pump, distributor, studs, and head gasket. 6:1 compression, 4 plugs. 211A P. 425
