I have never heard these switches were temperamental. If you are keeping the original wiring circuit and just going to 12 volts there shouldn't be a problem as a 12 volt system uses less current. What year is your car?We are doing a full rewire on a v8 , and want to use the original column drop ignition switch and know these can be a little temperamental , would it be necessary to fit a hidden relay to take the load off this switch? Thanks .
Hyvolt, would you post a picture of your wiring panel.
