rotorwrench
If I ever get back on my AV8 project, I'm going to set it up like an aircraft electrical system. The column drop switch will power up the battery relay. I use a big continuous duty one for high amp capability. I'll use Klixon circuit breakers for all the individual circuits set in a master electrical distribution panel. I've got a lot of that stuff around from being in the aviation business so long. The wiring will all be generic aircraft wire with numbered shrink sleeves at each end of the wire. The only color used is white PTFE insulation and the wire is silver plated. I like a nice clean heavy duty set up.
The old cloth covered wire Ford used still gives me nightmares. After about 15 years from new you can't tell what color the wire is anyway.
