BUBBAS IGNITION
Need some help on the Harmon Collins distributor for the flathead. I have done quite a few of these with little reference to the actual firing order.
We rebuild the unit, and sync each set of contacts on a syncograph with eight lights making sure the lights line up evenly etc. Never actually runing one on a car...
I am aware it uses a different firing order when you use twin ignition coils, caps and rotor etc.
Someone have the correct litature for the Harmon Collins firing order .???
Thanks
Jim at Bubbas
Thanks
Jim at Bubbas
