glennpm Well-known member May 2, 2025 #161 snap ring on axle speedo end Attachments IMG_20250414_082101.jpg 58.2 KB · Views: 128
glennpm Well-known member May 2, 2025 #162 37 e brake Attachments 2025_05_02_13_00_36_1937_1938_Ford_Passenger_Hand_Brake_Lever_Bracket_Assembly_NOS_78_2795_O.jpg 14.5 KB · Views: 158 2025_05_02_13_01_06_1937_1938_Ford_Passenger_Hand_Brake_Lever_Bracket_Assembly_NOS_78_2795_O.jpg 27.2 KB · Views: 162 Clipboard_05-02-2025_01.jpg 4.7 KB · Views: 160 2025_05_02_13_59_11_2025_05_02_13_57_20_1937_1938_Ford_Passenger_Hand_Brake_Lever_Bracket_Assemb.jpg 38.6 KB · Views: 151 Last edited: May 2, 2025
glennpm Well-known member May 10, 2025 #163 Power valves Attachments JWL on PVs.jpg 145.6 KB · Views: 300 RumbleSeat's reply.jpg 40.4 KB · Views: 307 Techo Section.jpg 17.5 KB · Views: 299
glennpm Well-known member May 10, 2025 #164 valve adjustment Attachments Valve Adjustment Wheel.jpg 33.8 KB · Views: 117 Valve Adjustment Wheel - Ford.jpg 37.1 KB · Views: 19
glennpm Well-known member May 14, 2025 #165 Cam curves Attachments Cam_Comparisons GPM.jpg 38.7 KB · Views: 31 Cam Comparisons.pdf Cam Comparisons.pdf 66 KB · Views: 23 Cam Comparisons Wheel.jpg 54.4 KB · Views: 147 Cam_Comparisons GPM2.jpg 52.5 KB · Views: 149 Last edited: May 14, 2025
glennpm Well-known member May 17, 2025 #166 resistor bypass Attachments 2025_05_17_07_12_02_Wiring_Dia_Colors.pdf_Foxit_PDF_Editor.jpg 61.7 KB · Views: 206 Last edited: May 17, 2025
glennpm Well-known member May 19, 2025 #167 Advance Attachments Advance-Retard Positions.jpg 74.8 KB · Views: 378 DSCN2928.JPG 62.9 KB · Views: 87 DSCN2929.JPG 62 KB · Views: 81 DSCN2930.JPG 72.2 KB · Views: 26 DSCN2931.JPG 63.9 KB · Views: 76 Last edited: May 19, 2025
glennpm Well-known member May 20, 2025 #168 My cars Attachments DSCN5025.jpg 84.5 KB · Views: 392 IMG_1128 crop.jpg 70.2 KB · Views: 384 2025_05_24_10_45_29_Ford_Green_Book_ALL_PAGES.pdf_Foxit_PDF_Editor.jpg 63.8 KB · Views: 79 Clipboard_06-04-2025_01.jpg 38.1 KB · Views: 92 Last edited: Jun 4, 2025
glennpm Well-known member May 31, 2025 #169 Fuel bell Attachments Tank Unit Schematic.jpg 47.4 KB · Views: 84 DSCN2936.jpg 92 KB · Views: 107 DSCN2937.jpg 26.7 KB · Views: 116 Last edited: May 31, 2025
glennpm Well-known member Jun 11, 2025 #170 36 column drop Attachments 2025_06_11_16_56_22_Ford_Green_Book_ALL_PAGES.pdf_Foxit_PDF_Editor.jpg 7.8 KB · Views: 69
glennpm Well-known member Jun 15, 2025 #171 retread job Attachments IMG_3543.jpg 67.9 KB · Views: 215 IMG_3537.jpg 43.7 KB · Views: 31 IMG_3538.jpg 36.9 KB · Views: 220 IMG_3547.jpg 37.9 KB · Views: 219 IMG_3545.jpg 67.2 KB · Views: 222
glennpm Well-known member Jun 22, 2025 #172 8BA timing Attachments Timing Cover Pin.jpg 46.4 KB · Views: 165 8BA_6312_B_Crankshaft_Pulley_Dual_Groove_Wide_Belt_Pulle_Brave.jpg 32.2 KB · Views: 145 Timing adjustment.jpg 87.8 KB · Views: 114 Last edited: Jul 30, 2025
glennpm Well-known member Jul 4, 2025 #173 Ungrateful Attachments Ungrateful Colonials.jpg 51.8 KB · Views: 73
glennpm Well-known member Jul 7, 2025 #174 carbs Attachments DSCN2975.jpg 71.2 KB · Views: 463 #3 plug color.jpg 30.6 KB · Views: 459 #4 plug color.jpg 28.1 KB · Views: 18 Clipboard_07-08-2025_01.jpg 40.6 KB · Views: 376 Clipboard_07-08-2025_02.jpg 31.5 KB · Views: 365 K&N Filters.jpg 58 KB · Views: 273 Last edited: Jul 16, 2025
glennpm Well-known member Jul 9, 2025 #175 51 horn issue Attachments 2025_07_09_15_48_35_1951_1954_Car_Horn_Button_Contact_Wire_Early_Ford_Store_._San_Dimas_CA_Brav.jpg 69.6 KB · Views: 124 2025_07_09_15_44_41_Clipboard_07_09_2025_01_IrfanView_Zoom_1489_x_1985_.jpg 50 KB · Views: 127
glennpm Well-known member Jul 14, 2025 #176 Shock angles Attachments Clipboard_07-14-2025_01.jpg 24.6 KB · Views: 178
glennpm Well-known member Jul 17, 2025 #177 Light switches Attachments 1928-1937 Headlight Switch.jpg 28.7 KB · Views: 140 1938-1939 Light Switch.jpg 29.6 KB · Views: 131
glennpm Well-known member Jul 19, 2025 #178 Brakes Attachments 2025_07_19_13_04_59_Ford_Green_Book_ALL_PAGES.pdf_Foxit_PDF_Editor.jpg 20.8 KB · Views: 106 2025_07_19_13_08_39_juice_brakes_drag_when_rotating_only_one_way_The_Ford_Barn_Brave.jpg 24.3 KB · Views: 20 2025_07_19_12_57_44_juice_brakes_drag_when_rotating_only_one_way_The_Ford_Barn_Brave.jpg 21.9 KB · Views: 104 Clipboard_07-21-2025_01.jpg 60.3 KB · Views: 107 Last edited: Jul 21, 2025
glennpm Well-known member Jul 27, 2025 #179 carb pics Attachments DSCN3973.JPG 167.7 KB · Views: 119 DSCN3975.JPG 145.6 KB · Views: 27 DSCN3976.JPG 113.2 KB · Views: 110 DSCN3977.JPG 108.9 KB · Views: 121 DSCN3978.JPG 143 KB · Views: 123
glennpm Well-known member Aug 30, 2025 #180 Heads and crab Attachments DSCN4145.jpg 66 KB · Views: 250 DSCN4146.jpg 67.3 KB · Views: 19 DSCN4152.jpg 48.3 KB · Views: 245 DSCN4149.jpg 33.4 KB · Views: 236 DSCN2626.JPG 78.8 KB · Views: 159 DSCN2622.JPG 93.6 KB · Views: 161 DSCN2623.JPG 98.8 KB · Views: 159 DSCN2624.JPG 85.8 KB · Views: 18 DSCN2625.JPG 79.2 KB · Views: 154 DSCN2629.JPG 99.8 KB · Views: 149 DSCN2630.JPG 94.2 KB · Views: 157 2025_09_07_10_39_20_Distributor.pdf_Foxit_PDF_Editor.jpg 25.5 KB · Views: 210 Cam angle for Ford Distributor 2.jpg 35.7 KB · Views: 74 Cam angle for Ford Distributor 1.jpg 106.5 KB · Views: 39 Re-paint of TDC Marking.jpg 30.6 KB · Views: 202 Last edited: Sep 18, 2025
