Glenn's test for photos
Driveshaft Center Bearing replacement
Columbia Stewart Warner speedo transmission
LZ Columbia Speedo Gears
  • 2026_01_05_07_12_36_Extracted_pages_from_Techno_Source_for_the_1932_thru_1953_Flathead_Ford 2.jpg
  • Extracted pages from Techno Source for the 1932 thru 1953 Flathead Ford.jpg
Column Drop
Block bearings
6 volt headlight relay
Re: 6 volt relays
"I was told a couple weeks ago on Fordbarn that Bosch makes a good one but never found a 6 volt one."
Early 1950-60 VW uses them:
Bosch SPDT
6V 30 amp Relay
0332204001
Used as dimmer relay
In 1950 to 1966 VW
Also listed as:
Merced 0035340245
Porsche PCG61510100
John Deere AR91168
Search post and threads
1946-48 wiring diagram
69A Canadien Block
The images below are from the "Green BooK". The length should be 10-1/16" between mounting holes.
Crab internals
  • 2026_02_02_06_37_42_1099_Composite_and_Year_End_Summary_2025_377.PDF_Foxit_PDF_Editor.jpg
water pumps
Mallory Unilite
  • 2026_02_25_07_34_47_Mallory_Unilite_Distributor_Page2.jpg_IrfanView_Zoom_866_x_1120_.jpg
  • 2026_02_25_07_36_53_Mallory_Unilite_Distributor_Page2.jpg_IrfanView_Zoom_1394_x_1805_.jpg
Resolution testing
320×480 – Typical for older or smaller smartphones.
larger pics below are 360x480
582451
360×640 – Common for low-end smartphones.
414×896 – Seen on some iPhone models (for example, iPhone 11).
375×812 – Standard for iPhone X and similar models.
412×915 – Popular on mid-range Android smartphones.
582448
582449
582450
Roadster on frame
