glennpm Well-known member Jul 27, 2026 #241 Tail lights Attachments DSCN1177 red.jpg 90.7 KB · Views: 99 DSCN1178 red.jpg 79.9 KB · Views: 103 DSCN1179 red.jpg 50.6 KB · Views: 104
glennpm Well-known member Jul 29, 2026 #242 Standard PCV V100 valve Attachments DSCN4846.jpg 61 KB · Views: 108 DSCN4848.jpg 51.7 KB · Views: 21 DSCN4850.jpg 65.3 KB · Views: 26 My 59A PCV Mod.jpg 88.2 KB · Views: 103 Last edited: Jul 29, 2026
glennpm Well-known member Aug 1, 2026 #243 Torque tube bearing Attachments DSCN2538.jpg 62.2 KB · Views: 161 Skip_Haney_Torque_Tube_center_bearing.jpg 100.3 KB · Views: 166
glennpm Well-known member Aug 3, 2026 #244 Owl's head Attachments DSCN4857.jpg 79.5 KB · Views: 22 DSCN4860.jpg 96.8 KB · Views: 30 DSCN4865.jpg 99.1 KB · Views: 26 DSCN4868.jpg 84.9 KB · Views: 17 DSCN4869.jpg 100.2 KB · Views: 11 DSCN4870.jpg 79.3 KB · Views: 18 DSCN4874.jpg 89.8 KB · Views: 13 DSCN4876.jpg 75.7 KB · Views: 23 DSCN4877.jpg 89.6 KB · Views: 15 DSCN4883.jpg 86.2 KB · Views: 25 DSCN4886.jpg 82.8 KB · Views: 17 DSCN4891.jpg 80.9 KB · Views: 20
glennpm Well-known member Aug 7, 2026 #245 Vintage OEM 1935-48 Aluminum Flathead Ford V8 Intake Manifold Attachments Intake.jpg 113.6 KB · Views: 102 Intake 2.jpg 34 KB · Views: 102
glennpm Well-known member Aug 7, 2026 #246 Suspension torque values Attachments Suspension Torque Values.jpg 97.5 KB · Views: 108
glennpm Well-known member Aug 8, 2026 #247 Paint repair Attachments DSCN4915.jpg 23.7 KB · Views: 385 DSCN4916.jpg 43.2 KB · Views: 377 DSCN4917.jpg 23.2 KB · Views: 24 DSCN4975.jpg 73.9 KB · Views: 133 Fender.jpg 58.8 KB · Views: 106 IMG_4390.jpg 46.9 KB · Views: 91 IMG_4393.jpg 86.8 KB · Views: 87 DSCN5013.jpg 40.6 KB · Views: 54 Last edited: Sep 26, 2026
glennpm Well-known member Aug 10, 2026 #248 Utes Attachments DSCN4179.jpg 69.8 KB · Views: 220 DSCN4180.jpg 65.9 KB · Views: 32 DSCN4181.jpg 70.2 KB · Views: 215 35 Top Brackets.jpg 44.1 KB · Views: 92 Last edited: Aug 14, 2026
glennpm Well-known member Aug 17, 2026 #249 cam lifts Attachments Cam lifts.jpg 29 KB · Views: 55 Last edited: Aug 21, 2026
glennpm Well-known member Aug 27, 2026 #250 Distributor leak Attachments Front motor view of disy mount.jpg 67.8 KB · Views: 25 Bottom leakage.jpg 84.4 KB · Views: 139 Front motor view leakage.jpg 70.6 KB · Views: 142 Gasket being removed.jpg 61.3 KB · Views: 132 Used gasket.jpg 95.5 KB · Views: 13 Oil in distributor.jpg 79.8 KB · Views: 149 3-Bond.jpg 58.4 KB · Views: 94 Ultimate Grey.jpg 43.3 KB · Views: 96 Last edited: Aug 28, 2026
glennpm Well-known member Sep 2, 2026 #251 35-36 columbia controls Attachments 1935-1936 Columbia Controls.jpg 123.3 KB · Views: 119 2026_09_03_07_47_14_Greenshot.jpg 56.9 KB · Views: 241 Real_Main_Seal_Instructions.jpg 54.2 KB · Views: 148 Last edited: Sep 7, 2026
glennpm Well-known member Sep 7, 2026 #252 Getting email notifications Attachments Gettig email notifications - edit options.jpg 63.7 KB · Views: 85 Gettig email notifications.jpg 72.8 KB · Views: 72
glennpm Well-known member Sep 8, 2026 #253 Rope seal Attachments Clipboard_09-08-2026_01.jpg 201.7 KB · Views: 110 relays for heater.jpg 57.6 KB · Views: 79 Last edited: Sep 8, 2026
glennpm Well-known member Sep 10, 2026 #254 KRW engine lift rig Attachments KRW motor lift plate.jpg 41.1 KB · Views: 101 KRW motor lift plate.jpg 2.jpg 166.9 KB · Views: 74 32 Cowl Detail.jpg 43.5 KB · Views: 114 Last edited: Sep 11, 2026
glennpm Well-known member Sep 11, 2026 #255 Holley fuel Pressure regulator#12-804 Attachments New & thicker 3-16in brake line.jpg 44.6 KB · Views: 177
glennpm Well-known member Sep 12, 2026 #256 34 to 35 block ventilation change Attachments 34 to 35 ventilation changes 1.jpg 221.2 KB · Views: 132 34 to 35 ventilation changes 2.jpg 45.1 KB · Views: 115
glennpm Well-known member Sep 14, 2026 #257 Pressure regulator Attachments Regulator open with spring removed.jpg 63.4 KB · Views: 14 DSCN5404.jpg 52.6 KB · Views: 68 DSCN5398.jpg 60 KB · Views: 19 DSCN5402.jpg 63 KB · Views: 21 DSCN5403.jpg 54.8 KB · Views: 75
glennpm Well-known member Sep 14, 2026 #258 Rear brake shoes and emergency brake setup Attachments DSCN1478.jpg 75.3 KB · Views: 25 Our servers are down.jpg 47.6 KB · Views: 105 Last edited: Sep 19, 2026
glennpm Well-known member Sep 22, 2026 #259 Edelbrock head & Columbia knob Attachments 2026_09_22_06_37_34_2026_09_22_06_29_30_Techno_Source_for_the_1932_thru_1953_Flathead_Ford.pdf_F.jpg 51.1 KB · Views: 162 IMG_4419.jpg 22.6 KB · Views: 65 IMG_4420.jpg 22.9 KB · Views: 73 IMG_4421.jpg 19.2 KB · Views: 73 Last edited: Sep 24, 2026
glennpm Well-known member Sep 25, 2026 #260 Gasket hole smaller than block hole Attachments Gasket to block hole comparo.jpg 169.7 KB · Views: 89 Factory Block Relief.jpg 140.8 KB · Views: 171 Last edited: Oct 4, 2026
