CWPASADENA
[QUOTE
This is a negative ground 6 volt car.
[/QUOTE]
If you have the battery hooked up for NEGATIVE GROUND, the DIODE Cut out will not work.
The Model A is designed with a POSITIVE GROUND electrical system.
Install the battery so it is POSITIVE GROUND and see if that corrects the problem.
You should re-polarize the generator after you re-install the battery.
My opinion
Chris W.
[/QUOTE]
My opinion
Chris W.
