eric.schaefer
1931 cabriolet was running great, now the battery goes dead in less than a day. I can charge the battery and drive it and then the next day it is completely dead. Won’t even run the horn or lights it’s so dead. I’m not sure how accurate the amp meter is but it does show 15 amp discharge when the key is off and the car is sitting. So something is pulling power when the car is just sitting there.
This is a negative ground 6 volt car. There is no fuse on the starter
Here is what I have checked.
-brake light and lights are not constantly on or stuck on.
- battery cables are not damaged or rusted. Good ground on the negative to the transmission.
-changed the coil out just because it was easy and I had another good coil.
Thanks for any help.
