Tom Endy
An alternator is much kinder to your battery than is a generator. The regulator circuit in an alternator is constantly looking at the condition of the battery and only sends charging current to it when needed. This way the battery stays fully charged and is never overcharged. The result is a longer lasting battery, and easy starting.
A generator on a Model A puts out a given amount of current to the battery depending on where it is set. If you drive a lot at night the battery is generally never fully charged and you may have trouble starting the engine. If you drive on a long day trip the battery may become overcharged and will start boiling the water out and possibly buckle the plates.
In the old days it was common to see cars on the highway during the day with their lights on to draw off the current and prevent the battery from being overcharged.
If you are going to drive your car a lot or go on long tours an alternator is the better choice. If you are just going to drive it occasionally or show it, a generator will work fine. And it will please all the purest.
One of the best kept secrets in the Model A hobby is Becker Antique Electric in Norwalk, Ohio. Larry Becker sells 6 and 12 volt alternator kits for the Model A for $85 with a lifetime guarantee. 419-668-5986.
Tom Endy
Tom Endy
