Charlie ny
Rs,
Let's just say it was me that did the work. Send the carb and distributor back pronto I'll set them up again. What is the condition of your inner distributor caps ? Too
big a gap between the tips of the rotor and the inner terminals can cause this issue.
Be sure to check continuity of the spark plug wires and inner caps. This wire
and cap continuity can be checked with a simple battery operated test light. What
I do is clip one end of the test light onto the spark plug end of the wire and clip the
other end onto the correct terminal on the inner cap. It is not uncommon to find one or two wires with no continuity.
Charlie
Charlie
