Phil Gillespie
Will do as suggested by you and Tubman. It will only be on to test out.
I’m working my way down the list.
1 carbs cleaned and reset - need to finish that this am
2 jumper to coil
3 points and rotor
It’s not the pump. I recall now when car would not start I verified it was pumping fuel to carbs.
Are you 6 or 12v as per previous posts not normally required the resistor if running 12 v. Only required with 6v when running original type coil.
Phil NZ
