34 fordor owner
34 tuning, running, etc…
Creating another forum…this time with good news and questions….I’ll continue to post my update videos here I highly appreciate all the input. I got my new fuel line flex line on today and I ran into an issue where the threads on my pump are really messed up but no leaks and the car still ran off the fuel pump. I was able to drive 2 laps around the block and it went very well!! Before it stopped running (2 years ago) it was backfiring a lot but this time there were some small pops from 2nd to third but not much at all. With all this I tuned the Holley 94 carb based off other posts I have read. Turn in until the screw bottom out, 1-1/2 turns back out. Then let it warm up and I turned the screw in until it started to die and backed them back out a little. Is this all correct? I included 2 videos of it idling to see if anyone can tell me anything. The first video is before it went around the block and I can hear a vacuum leak or maybe not a leak? somewhere but wasn’t sure where from. The second video is from after the drive around the block and I pointed out the fuel and bowl were nasty so that will be taken back off and cleaned before the next drive. As well as the tank will be drained. Adding to this I need to get my oil bath air cleaner restored as well as my oil breather. Thanks for all the help!
https://youtu.be/a_sjkgXytwU?si=p0InGTr7L1dv4Ea6
