all american boy
Fordy's
what's the oil route through the pump?
Have A Nice Day!
Have A Nice Day!
I've got a question on the pipe going into the pump...on my 312, the nut holding the pipe to the pump was loose and it was misting oil every where. Once I figured out that nut was loose I tightened it but reading the above posts has me concerned. I didn't "kill" it when I tightened it but I snugged it up good. Is there anything I should check to make sure I didn't over tighten it???
Also, what sort of oil pressure should a y-block have? I have a mechanical oil pressure guage and it reads 40 psi while driving but drops down to 20 psi when idling (once the engine is warm). Is this ok?
