I believe the fuel pump block-off plates are the same part for both.Not wanting to hijack the thread, but do they have those for FE's, too? I know "google is my friend" but so are many of you guys.![]()
It's my understanding the fuel pump block-off plates are the same part for both.
I suspect those plates were the same at least into the 70's, on nearly all the Ford V8 engines.Okay, I found one, I think.
Thanks dmsfrr and Paul2748. I put a new mechanical pump in my T-Bird recently, and one in my old Mercury about a dozen years ago, so I'm probably ok, but I've decided if I ever need to replace either again I'll go electric.
I'm sorry I'm not more acquainted with electric pumps, but I've never installed one on an old car. Anyway, here's my probably dumb question: Are most aftermarket electric fuel pumps now designed to stop running when the engine stops (as in an accident)? That was an unappealing feature of aftermarket electric pumps at one time...they kept running after a collision. I know they fixed that on new cars, as the pump needs to be reset after a fender bender, but I wasn't sure if aftermarket pumps were also like that now.
Read the TECH ARTICLE - http://www.how-to-build-hotrods.com/electric-fuel-pump.html -
