dmsfrr
Hopefully this is an easy one...
When assembling a Y-block engine the correct installation position for the timing marks on the crank & cam timing chain gears is:
Both gear timing marks at 3 o'clock with 12 timing chain pins between the marks.
Now for my question...
With the crank & cam in this position is the engine at cyl. #1 TDC on the firing stroke, or is it somewhere else?
