Hello All,
I need some help finding the correct camshaft for a stock 292 rebuild. The engine has been bored .060" over. The truck is a F100 with a 3 speed manual transmission with what I believe to be a stock rear end with 3.92 gears. This is to remain a stock driver. I've toyed with the T5 transmission swap but I'm not sure.
It was recommended to me to use a cam with a duration of 256/208 a lift of .435 with the stock rockers (1.54") lobe spacing of 110, a lash of .014" for use in an RPM range of 1500 - 4500.
I've located a B8A-6250-C NOS shaft but can't find the specifications. Could someone point me in the right direction????
Many Thanks,
Mike
Many Thanks,
Mike
