NCSUDucker
The 39 1 ton definitely needs rewiring. Seems to be a task I can handle as it looks to be fairly straight forward and pretty much plug and play so to speak. I've been building wooden duck boats and wiring them for 20 years...can't be too much different other than 6v vs 12...right?
I'm trying to determine the harnesses I need for a complete rewire. The biggest question I have is for the cowl harness. The options for the 39 at Carpenter are include the voltage regulator, which in searching the forums, it looks like that was mid year switch over. I believe my truck has the voltage regulator (again pardon my ignorance as automotive is all new to me). Attaching a pic. If that is the case then I'm assuming that would be the correct harness. However, CW Moss has harnesses for 1939 trucks that include 2 & 3 brush generators. Just want to make sure I am ordering the right harness.
Aside from the cowl harness, I'm assuming I would need the headlight harness, tailight, and tailight crossover. With this truck having the heater and turn signals, I'm assuming I would also need some spare by the foot cloth covered wire to tap in where needed. And of course plenty of female connectors. Am I missing anything? Spark plug wires look to be fairly new and not in need of replacement.
Thanks in advance. Everything aside from the horn (which works intermittently) is currently working but a lot of cracked and few bare wires here and there. If you know of something else I would need please feel free to share.
Brad
Brad
