You'd have to connect the coil dirrectly to the points, then run the power wire to one side of the switch and connect the other coil primary and anything you want switched to the other switch terminal. Just be sure the switch contacts can handle the power going through it. Some of the repro switches I've seen can barely handle the coil current.no pop out switch,what do I modify
