Winter build project T body
Thanks Don, now I'm on the right track, after thinking about my post yesterday, I realized you need to let the joints "give" a little. Makes sense now how the body is fastened together.
JJ
I did not give the size of the wood fire wall. Check page1 photos#2. The fire wall should be 39 1/4" X27" X 3/4". The wood fire wall must be in place as it determines were the body mounts go. I used a pre 23 windshield.
The body sides are 2 pcs. 9"X 77 1/4" X 7/8". Seat (front) 9 1/2" X 42 1/2"X 7/8"(back)9"X 77 1/4" X 7/8".
For this I went to Home Depot. Got sheet of poplar PLWD 23/32" 4' X 8'.$39.28
I had them cut it 2 pcs. 9" for sides. 1 pc. 9 1/2" for seat. Cut the last pc.to size.Then strip 1/2" off 1pc.. They will do the cuts Free.
Now you should get a Qt.of oil paint start your painting.
Add the trim 1 1/4"X 1/4". Where you see it in last photo.Before you add the front trim. You should make a piece of tin for the front corners.4" X 6" bent over and screwed to side of and front of seat. These are painted black. Thats up to you. Now that trim can go on over the tin.
I went with a quick build on mine. I have had it on the road for over 5 years. Ash framing, fir slats for top, ash plywood for sides. The side boxes are pine. I did drop the top down about 4 inches as it looked to tall and narrow along with the wind really blew over the top of the windshield. The next change would be to enclose the cowl area a little more.
MarkG
Hi redmodelt That's a neet little T. Those rear springs must help when the wind bad.
As you know a cross wind is bad on a model T.
I tore mine apart to clear coat and paint before I got to far along. But you will need the tail gate size.8 1/2" X43 3/4" X 3/4". You will need 125 1/2" of 3/4"X 1/8" steel. To go around the tail gate.
I will give it 3 coats of clear. Steel wool it between coats. Then tape it off and
paint it. And paint all the steel. Before I put the steel back on. I will take photos
and measurements. Then you can have fun making the steel parts.
I added the Hasslers only on the rear. She had too much sway going around some corners. I did find they do help. The same corner at the same speed, more stable.
Took it apart and started to paint. This is what I have done so far.
Hi 32 chevy vett,
Looks great, I like your color choice, beautiful work. Thanks again for sharing the project with us.
JJ
6 pcs.15 1/4" X 1"X 3/16" Bend as in photo. 9"up make a 90* go 1" make a 38*.
Shape the bottom. Cut off a 3/8" bolt 2 1/4" long and weld it to the shaped end.
Lay flat so the bolt is offset then fill offset with weld. Then grind to shape.
Now drill for 1/4" carriage bolts. Up on the 38*1 1/2" drill first hole 3" more
drill second hole. Now you have to line the body with the tail gate in place.
You have to drill 3 3/8" holes.From the back of the rear bumper 10 1/4"- 32"-54" set the piece you made in place put a nut on it and tighten. Now drill the hole in the center of your trim.
I'm a bit of newbie here and this is an awesome build thread. Like others have said, I've got a pile of parts and was trying to figure out what type of body to build and your thread is really encouraging and inspiring. Can't wait to see more. -Matt
Thank you Matt. Welcome to the site. We will need 4 pcs.2 1/2" X 3/4" X 58 3/4". These will be the side rails.
For the steel in photos. You need 2 pcs.1" X 3/16" 18 1/2" long.
2 pcs. 1" X 3/16" X 20' long.
Drill before you bend. Drill and countersink for the screws.
From bend on bottom 1"-4". Countersink for #12 X1 1/2" screws.
These hold the front post to the seat.
I drilled all 1/4" holes out to 5/16" for carriage bolt heads. I painted all steel hardware. Next is the final fit and finish. Replace the philips screws with slotted.
Replace all hexagon nuts with square nuts. Put washers under all nuts. Save a small amount of mixed paint in a air tied bottle. To paint the nuts and screws.
This is the last of the steel. i picked this one up at Hershey. I still have not made mine. You will need 2 pcs. 12" long X 7/16" round stock. Drill a 7/16" hole 3 3/4" from trim.
Top sides. 2 pcs. 4" X 3/4" X 9'. Rear 1 pc. 44 3/4" X 3/4" with 1/4"rise in center.
Clamp rear piece to two rear posts. Clamp the 9' side piece to rear post. Over lapping the rear piece.Now clamp to #2 post. At post #1 make a 6 3/4" circle
down 2" from top. Make a curved line. From top of circle to the bottom front end of of piece. Make a curved line from post #2 - 1 3/4" above the lower line.
I got the curve by clamping a 3/4" X 1/8"piece. To starting point and finish point. And adjust the curve. Then trace the curve I got. Do the same with all top pieces. After you get the first piece cut out. Trace on the second piece.
Chevy Vette....I am so impressed with your work!!! Your EXCELLENT documentation is a blessing to us all.
THANK YOU FOR POSTING THIS....YOU ARE A MASTER!!!!!!!!
32 chevy vett,
Thanks again for posting your project, I really appriciate all the information you are sharing. I think Curt in the last post said it all!
JJ
