The glass shop that made my glass said that there was no magic trick- they score it on both sides with a glass cutter, and basically use brute force to tear through the laminating material. After that, I guess some grinding and possibly polishing are needed to get an nice-looking edge where necessary.how do you cut laminated glass?
You score and run each side of the glass. Then a flammable liquid, usually denatured alcohol is applied along the score and ignited. The heat from the burning alcohol softens the plastic (polyvinyl butyral) that is sandwiched between the glass so that the score can be opened up. A razor blade is used to cut the plastic.how do you cut laminated glass?
Doug
I thought they put a fluid on the score and lit it on fire to melt the plastic?![]()
Here is the windshield that was on my 1937 Ford. Pretty Bad. This is a factory windshield. I restored the windshield with glass from Saunders.
