I took the drivers window out of my 29 Murry 4 door to replace it. I took the entire mech out and removed the regulator to clean and lube it. After replacing the regulator I noted the window would not fully roll down. The regulator was rolled all the way to the end, but the window was sticking up approx 1to 1 1/2 inches above the door. Will roll all the way to the top. I ckd the arm on the pass side and rolled down it is 50 Degrees. The arm on the drivers door is 30 degrees rolled down. As far as I know nothing was changed. I've been banging my head against the wall for a week trying to figuer this out. HELP
