david.skinner
There are a lot of people on here more experienced than me but here is my 2.5c. As an electrical engineer 5amps sounds high to me. The heat required to be dissipated by any device is the square of the current x its resistance. In this case this is 5x5x1 = 25W. That is a lot of heat to be dissipated by any device let alone by a sealed device like a coil.
The voltage created by the secondary winding is determined by the magnetic field collapse in the coil so you only need enough current in the primary to fully charge the coil magnetic between firings. Any more will just overheat the coil but not give a better spark. My 38 coil draws an average of 2 amps by using a 2.7 ohm series primary resistor which would give around 4w of heat dissipation in the coil. Quite a bit different from 25w. Just a thought.
Regards
David
Regards
David
