pheaton charlie
I have a complete 52 lincon flathead V8. It turns over by hand not sure the last time it ran or the cubic inch. thanks chuck
If you have a '52 Lincoln flathead, it's probably super rare, thought the last year for the Lincoln flathead was 1951. (otherwise it would make a good boat anchor)I have a complete 52 lincon flathead V8. It turns over by hand not sure the last time it ran or the cubic inch. thanks chuck
Like 51 Merc-CT said, '51 was the last year for the Flathead in the Lincoln, it was a 337 ci. You don't say where you are located... We have a '49 Cosmopolitan convertible with a 337 and I'd like to have an "extra" if it is a good one and you are close to Tampa, FL, please let me know. Vic
Dale, is your 337 matted to a Hydro-Matic or a 3 speed with OD? Our '49 Cosmo has the 3 speed w/OD. Vic
Mine's like yours-in fact it came out of a '49 Cosmo. It now resides in my '53 F-100.
That's interesting, how did you set up the front motor mount, did the 337 line up with the '53 motor mount that bolts to the front of the block on a 239 and into the cross member?
yes i'm from youngstown ohio. was just wondering the guy I got it off of told me it was a 52. I never ran any #s on it but it has lincon on the head so I assumed it was a lincon. I have no clue about flatheads. Was going to look for a model a or t sedan to put it in but the plant closed that I worked at and thought I might get a few bucks out of it. Thanks for all the info
