I carry the original tool set that came with the model A in the original imitation leather tool pouch, a feeler gauge a dist. cam wrench, sand paper, dist screw set,a coil terminal nut, starter terminal nut, a few odd and end nuts and bolts, electrical tape, a wire with aligator clips on both ends,Original owners manual in the door pocket, otiginal jack, tire iron and hand crank. I also carry a modern style condenser in the tool pouch that I could connect to the coil terminal in an emergency. The only thing that I have ever had to use was the hand crank , Once when the starter push rod fell loose,shorted against the starter terminal ,burned up the grommet in the firewall and nearly killed the battery and another time when I had oiled the helix on the starter bendix and the starter would just spin but not engage .
