Tractor motor??? Note the idler pully
The tube is a B tube. Might be a B motor but need to see the motor from both sides to tell.
Looks like a Model A engine with an aftermarket script head.
How can you tell a diamond block from a standard "A" block? Is there a diamond cast into the block or something? A diamond in the serial number?
Someone said industrial engines serial numbers do not start with an "A". Is this true? I heard industrial engines have different valve springs.
Let me know.
Thanks
Diamond engines had a small diamond cast in the block near the cam gear side cover.
I don't know about the serial numbers on industrial engines.
Is there a diamond cast into the block or something? Thanks[/QUOTE said:See the second photo in post #7. the <> is horizontal.
I have several heads identical to what is shown. They are Ford built heads cast after the A went out of production. Just in front of the water outlet you can see a date "tag" cast into the head. Gar Williams
