What is this ?
GT66PONY
Sorting out parts that came with my 1929 Closed cab. found parts I do not know! IMG_1067.JPG
Picture #4 looks like one of the plates that goes over the floor boards to cover up the gap around the steering column and peddles.
Picture #5, fuel line and spanner wrench.
Picture #6 upper left object looks like accelerator foot rest without the base.
1 and 2: 1928 pickup tail lamp bracket and rear mounted spare tire lock
4: pad under steering column area floor plate
5: water pump wrench and 28-29 gas line tank to firewall
6: steering column lower clamp, foot rest minus base plate,
Those C water pump wrenches are an invention from the '60's/'70's & are not necessary.
Ford always advised using the screw driver to just nip the gland nut sufficient to stop any leaks or after repacking, a lost art nowadays with the ubiquitous ''leakless pump.
The gland nut should not be tightened as it will then certainly leak on an original pump.
