Youngblood
Hi; I recently sold my Model A and bought a different one. This car has electronic ignition and a Weber 2 barrel Down Draft Carb on it with a fuel pump. The carb is set up with the 2nd barrel as progressive. When I drive the car it accelerates through the gears fine but on an incline, under a load it stalls out and I have to let off the gas and coast before I can give it gas again. The car does not stop running it just loses power. I did some research and so I have added a fuel regulator as Weber says it should not have more than 3psi of fuel to the carb. This has not changed the situation. I have changed the plugs and the old ones looked grey as if it is running lean. If there is anyone who has worked with these Weber Down Draft carbs I would like to get some advice. Please call me at (515) 491-8321. Mike Youngblood
