Finally got around to installing the pumps. All is well. I am also installing a radiator and have the mounting hardware but not quite sure how it works as the old mounts were a mixture of odd parts. For each side I have a rubber pad, a bolt, a nut, a cotter pin and two springs. No instructions. I assume: 1. the bolt comes up from the bottom; 2. the rubber pad goes on the top side; 3. a spring goes on top of the pad; the radiator flange then sits on the spring; 4. the other spring goes on top of the flange; 5. the nut goes on and is tightened; 6. the cotter pin goes in to keep the nut from backing off. This way the radiator is suspended between the two springs. Correct?
I have the two side brackets and they are easy enough.
Thanks!
