Neshkoro
Question one:
I'm having overheating issues. I've been searching for a new water pump, the new seal design that says " no leak" type. The current one leaks severely. They're pretty hard to find. Seems every supplier I've tried are sold out and their supply is on back order.
I've thought about buying one of the rebuilding kits. Has any one here bought and rebuilt one using a rebuild kit? Was it successful?
Question two:
Carburetor.I currently have a Tillitson carb. It also leaks from time to time. Seems the needle does not always seal off when the float rises and also the castings are warped. When I shut the car off gas pours out from the carb or sometimes as it is running it floods out, backfires and dies due to too much gas.
Same issue. carbs are hard to find and they're expensive as hell! Seeing as many of you folks are not fond of the Tillitson, I was thinking about getting a Zenith. Hard to find a brand new one or even a rebuilt one. I was looking on eBay and there are plenty of used ones, less than half the price than a new or rebuilt one. I was thinking of buying a used one and rebuilding it. What are your thoughts on that? I've rebuilt the Tillitson a couple of times. I know a Zenith is different and more complicated but I'm sure not too difficult.
Thoughts?
Thanks,
Bill
Question two:
Thoughts?
Thanks,
Bill
