Synchro909
Yes, that's what I had to do for a club member, but only two holes needed to be threaded and plugged.
As I recall it, 2 is correct but that was not a Russian B block. Maybe the Ruskies did it different!
Try retorquing the head again. FWIW Nothing to lose.
Paul in CT
Yep ,, keep doing it until you get no more movement on the nuts.
Twice is not enough
I always thought that if you use a B block with an A head you should plug the four steam holes and use an A head gasket. If your leak continues I would research this.
