Smooth_One
Please tell me where I can find the link that Werner posted?
I do not see a link on Werner's post ...
Did I miss something?
http://www.stant.com/index.php/english/products/consumer-products/thermostats/superstat-thermostat/
Is there a Gasket used between the Housing and Head, Or do you just use a Sealant. Thanks
Out in the garage last night til after midnight.
From what I can see in the pictures your cooling system is really clean.
What do you use for coolant?
Was the cooling system recently flushed with, if yes with what method (Water, Vinegar, thermocure, etc)?
Hi Smooth One
I recently flushed it with CLR and Vinegar, poured both in and let it run at just above idle for about 30 mins then let it sit overnight then drained everything out and flushed with water.
I’m running Green coolant 50/50 with distilled water and a bottle of Redline water wetter additive.
I spent an hour and a half cleaning the gasket surfaces last night.
I have a question on the Bert's water pump which I may order one as the Bratton's one is an issue. Is the shaft stainless and also brass? It looks like brass color on fan end in pictures.
What? No broken ears to contend with?
How can one be a Model A owner and not broken his ears?
Kidding of course. Ford design was a "work in progress" as evidenced by the three bolt Model B water-pump.
Joe K
Your first picture in #33 shows that you have a Canadian Powerhouse generator. Usually only see them on cars near the Canadian border or Model A's that Canada sent overseas.
