Vacuum wiper
Woodie1
I took my motor apart to clean & relube & now it won't run. I did take the switch part apart & was sure it went together the way it came apart. Any ideas on what I did wrong?
They can be fussy, but properly assembled they work well. I had one stop working while travelling a long way from anything. I pulled in under the pump roof of a closed gas station and took the wiper apart. The only thing I found was the paddle needed lube. All I had was some Vicks Vapo-rub. I gave the paddle a good swabbing, and it worked just fine, though for some time after the car had a medicinal aroma. Sometimes you just have to make do with what you have. True story.
