Timing pin in cam gear detent, spark lever all the way UP, turn the distributor cam clockwise until the points just close, then tighten the cam screw. You have to turn the cam clockwise to take up the freeplay, since the distributor cam turns COUNTERCLOCKWISE.
If you have to use too much advance, maybe you weren't taking up the freeplay in the distributor shaft.
