54sunliner
where should an original accessory 1954 mercury trunk light be mounted
I would think a 54' Merc trunk lid and a 53' Merc trunk lid would be very close, if not the same. This is a 53' Merc trunk lid.
This shows the wire location too.
That looks much cleaner.
Is the lamp factory, accessory kit or aftermarket?
It is factory and is controlled by the light switch on the dash.
By the HDL SW or an accessory switch?
THANX! for the info.
I was asking the OP as to what lamp he has. If a FORD KIT, it would be on the instruction sheet as to mount.
The headlight switch.
It only comes on when the headlight are on.
