I did a quick search and didn't find an answer about fittings on a 34 under seat gas tank, I need to remove it and clean it, the truck has been running on an aux side mounted tank and I want to run it on the seat tank again as we're not going to do 300 mile distance trips in a 3 axle 1 1/2 as the orginal owner did, looking at it there is a valve which the main line is hooked to and then a removable lid in the bottom of the tank with two fittings in it capped off, is that for the fuel line and gas gauge,or what are they.
Thanks
Aaron
Thanks
Aaron
