Once again we have been really busy at work this month. I have managed to get all four doors latched with my modified landcruiser fj 40 door latches. I fabricated some heavy duty striker plates and mortised them into the posts. I will be using '32-'34 pickup dovetails which arrived last week for added support and alignment, though everything works well as is. I also filled some holes in the front clip the easy way. There was a hole for a spotlight, so I installed one I had hanging from a nail on the shop wall. On the opposite cowl there were 2 holes for an antenna so I ordered one up and installed it. I latched the rear barn doors with a very nice '2 point slam latch'. Using any 5/16" square shaft handle it pulls both latch bolts with a twist and since the bolts have a 45 degree angle it can slam shut. It's all surface mount and looks 'commercial' in the desired truck based style. The seats pictured are temporary so I could do some fall cruising. I sort of picture a pair of old school bus driver's seats, up front. I think that's what my passenger seat might be, and a regular school bus bench seat for the back seat. You know the type, dark green with white piping. Ok, it's back down to the workshop.....
