You might also check the numbers on your shift tower. They are near the bottom (rear) portion on the raised piece in the middle. There should be two numbers followed by a hyphen and then 4 more. If I read Van Pelt's book correctly, if the first two numbers before the hyphen are "40", the trans is '35 or earlier (the tower is also slanted slightly to the rear) and it has only one detent plug. A "68" for these numbers means that it is a '36-'38 model again with a single detent plug. If you have a number starting with "81A" then it's a '39 or newer (with 2 detent plugs).
Hope this helps.
