Once again guys, thanks to all of you for the help. Just about finished the tear down on the 1950 Mercury M-68 (F3). I am trying to identify the transmission out of it. There is currently a PTO mounted on the ****** that I would like to remove as I am putting the original box back on the truck. The truck has an EAC motor and both the ****** and motor are painted blue.
Questions:
1. Is this the proper transmission for this truck?
2. Is it a 4-speed and can it possibly be a 5 speed?
3. If I remove the PTO is it a simple procedure ie unbolt and simply put on the plat which I currently do not have.
*Casting number on ****** case is 01T-7006 and on the shifter top is 041T-7222
Thanks
Questions:
Thanks
