Richard Knight
That is the weirdest transmission noise I have ever heard. Does not sound like a transmission noise at all. Also appears with clutch depressed no noise. It sounds like the clutch fingers are involved.
now that you have that ****** out.
start and run that engine.
that will eliminate any chance the noise is from the engine. then go back to the ******.
OU
I just started the engine. Its running very quietly - in so much as an engine with no exhaust connected, no transmission or flywheel cover, can run quietly. So the noise is not from the engine. But at least now I know!
Still perservering - bad weatrher, bad back!i am curious. did you find the cause of the noise?
That is great news!! Yes, I believe what your father sez is true. All Model As have a second gear whine, just some more than others. Enjoy!
