elwood
Hey guys this is a spare I ust to run in my roadster when i had a column shift in it, Can someone tell me what years this fits ?
As always, thank you all for the help
40 to 48 as mentioned above, however the rear mounts change thru the years. Should be a part number on it, or measure the width of the mounting bolt holes
I seem to remember a post in the last year asking the same question, about value of a side shift transmission, and the response was around $200. Your trans appears to have the 29-15 gearing which might be attractive to someone with the 3.54:1 rear axle ratio.
