Christopher Salty
S10 T5, would have overdrive
Curiously, I have never heard of this problem in shoebox-era Fords. I believe the gearsets are essentially the same, at least through late 1951. I have had a few of them, some pretty worn out, but they all stayed in second gear whatever other problems they may have had. Was there a design change? Perhaps, substituting some later model small parts may eliminate this problem?
As others have said, it is a result of worn parts - usually in multiple locations. Here are just some of the problems that can occur. The more of these issues you have, the more difficult it is to resolve them.
1) Excessive clearances/play between the snout of the main shaft and the front main drive gear. I would mic the snout of the main shaft to see if it is worn - if so, you'll need to locate a better one.
2) Worn caged needle bearings -- this is the one that goes on the end of the main shaft snout and runs inside the main input shaft. Beware - I have NOT seen a set of repop bearings that are worth a crap! Unless Mac VP says he found a supply, it is highly recommended that you reuse good originals or attempt to find NOS ones. The repop ones are usually not correctly hardened in the cage ends and they wear out in short order.
3) Worn 2nd gear bushing and too much slop/play on the fitment to the main shaft. The second gear needs a really precise fitment on the main shaft --> to the specific main shaft you're going to use. Frequently there is too much clearance, and this causes the second gear to "wobble" and this contributes to the problem. I have 'Charlie NY' re-bush my second gears to my main shafts - for just a slight drag between the two. This is one of the most important things you can do.
4) Cluster Gear Play -> too much front to rear play. This requires the fitment of the big thrust washers to setup the right play.
5) Synchro Hub Play and Second Gear End Play: There are thrust washers to setup the end-play between the synchro hub, second gear and the main shaft. Sometimes I have to use my surface grinder to accurately set the end-play. Sometimes I have to use a thicker washer and remove just a couple thousands from the back of second gear to set the end-play on the tighter side of the spec. I like to have about .002 to .003 of end play. It is difficult to "hold" the thrust washers in my surface grinder - which is why I sometimes have to massage the back-end of second gear
Okay - enough out of me . . .
……..and don’t forget the pilot bearing and pilot shaft bearing surface, this is were transmission align begins
Paul J
